Yes those were installed back on the same original positions
Excellent. Because if you swap them and mix their spots, the engine will sound like worn out crap...
Does your car have t stat n auto fan? Checked pcv?
fan is auto, t stat installed just recently while the pcv valve checked by myself it is working as a one way valve.
The numbers written on them with blue permanent marker. See the pictures.
Perfect bro. Lovely job.
Bad valve seals also cause smoke when car goes downhill. I noticed my margalla doing that on m2.
Your car will be better now
Caltex 10w30 changed at 3k km will really clean things up.
when installing valve seals, please use a straw to protect the stem seals and also use a deep socket to drive them home with a hammer - takes 2 taps at max
Deep socket used to slide the seals to its seat.
Result is amazing. No smoke at all in the morning.
The process
Congratulations !!!
Horse rider bhai....are u in khi?....i want to get the seals replaced too before its too late fr me.
I am in Islamabad, some members from Karachi will surely help
Thanks bro, the moment I turned the key my heart beat was going fast. But after seeing the tailpipe having no smoke, I got relief. I was waiting for that morning first start.
perhaps irshad can do it @capsat
yes it can be done parts need to be sourced by the owner. Suzuki parts are seriously compromised for a b c d grades.
Only need valve seals and valve cover gasket. Both are easy to get not much issue in parts dept for this job.
Only irshad's willingness needed
issue is with the end user not the person working who is keen to learn.
i see that 2 of the members attempted the task under their own supervision got the desired results. both know what they are asking and offered their pair of hands as assistance to USTAD. you know what i mean
Exactly. You need to help with the job and also maintain quality.
Like labelling the rocker arms, bringing rope. Handling bearings with care.
Or even explaining how to do it.
This is not wallet holder's cup of tea.
if you are free, discuss with the person for fee, take daewoo to karachi get the job done at workshop he will provide all tooling and learn from you. You can leave by Daewoo. I will be your driver
i can arrange your stay at nearby masjid . with my watchman for your security
