If you are hunting for flavors Congrats! Your hunt is over! As this atomizer was declared the best tank for flavor by the world famous vape forum i e vaping360
Aspire Nautilus 2 is a new and curvy tank which sports the lastest MTL (mouth to lung) 2ml juice capacity It employs 5 new 0 7 ohm BVC coil coupled with the bottom airflow adjuster helping you to fine tune your vaping needs
The price for both the new products is almost Rs 4 200 i e
1 Tank: Rs 2 700 for tank; and
2 Coil: 1 500 (5*300) for 5 replacement coil
Against Rs 4,200 our price is Rs 3,600 only (Discount of Rs 600/-)
Price reference from elite
Features and Specs:
Dimensions: 2-1/8β³x 7/8β³ (Including Drip Tip and Threads)
Diameter: 22mm
510 Threaded
2ml Capacity
Designed for Mouth to Lung
Shorter Chimney for Improved Flavor
Top Fill Design
Adjustable Airflow Control Valve
5 Different Airflow Settings
Glass Tank with Metal Sleeve
(2) Drip Tips Included
510 Drip Tip Compatible
Utilizes Aspire Nautilus 2 BVC (Bottom Vertical Coil) Kanthal Atomizer Heads for Variable Wattage
Includes (5) New BVC Kanthal 0 7ohm Atomizer Head (Recommended 18 β 23 Watts)
Atomizer Heads are Compatible with Aspire Nautilus 2 Nautilus and Nautilus Mini
It has two used coils of 1.8 ohm and 0.7ohm But i am giving that as free
Atomizer is very slightly used. Condition is almost new. Moving to another country, have to sell urgently.
However, the 5 atomizer are brand new untouched
Condition: 10/10
My office is at i.i.chundrigar road and life in johar, let me know whats most fesible for you.
03353230987
