ok guys so here we go to change the rear wheel oil seal on 1985 new bodyline
So this is the biggest and i beleive only symptom of oil seal failure
we have to remove the center axel nut to take down the wheel with durm still on, its a size 22 nut,
wheel drum off, you can see oil all over brake assembly, and inside brake drum too
old oil seal removed
cleaned everything including brake drum with petrol and then it starts looking like this
all needed is a new seal and seal adhesive tube
now put some adhesive on side of new seal and place it in seat of seal and press it down till its firmly seated, i use faulty seal to on top of new one before hitting it to be in place
place wheel back on
