So many errors, get the battery checked if it's generating enough voltage
@babarhyd it is a VEJEEL by ONDA
What model is this, any accident history?Reset the DTC and drive the car, if it reappearsYou will need to change VSA module.
can you please add me on vezel owner whattsapp group my whattsapp number is 03218847457
My vezel when i stuck in traffic after some time when i am on open road my race get stuck not getting enough power what is the issue i have 2015model thanks
Clutch can be replaced with new one on just 35K. If box need to replace add 18k more.
03139986357
How much is your cars mileage
Hi how often do you change this and the transmission oil?
Hi how often do you change the actuator oil and the transmission oil?Any recommendations on what mileage to change both
Same error faced in vezel 2014 , mechanic replace the part called Engine Control Unit (ECU Computer) which cost me around 50k and error gone!
sir any fluid changes ? or only ECU ??
Damn first time seeing someone with same first name
Cost of replacement plz
Haloo. The correct trasmission oil is not atf dw1 ultra . This is the reason people face so many problems in vezel clutch and gear. The correct oil is hcf 2 ultra and not 2 litters 3.5 litters. Its mentiones in its manual. I am surprised how whole nation is using a wrong oil in the cars and complaining that the vehicle has an issue. Both oil have very different cooling and heating properties. Please refer to the honda vezel manual. And stop using DW1 use hcf 2 ultra and not 2 litters 3.5 litters and change every 40 to 50000 km you will feel the change in milage in gear shifting even the ev mode. page 270 in manual
The manual you posted is for RU1/RU2 (Non Hybrid CVT models). Hybrid RU3/RU4 is DCT and this manual is not applicable for Hybrids.
Please send me number
