the original fan is two speed, it should kick on to high speed once the A/C head pressure increases, its controlled by a sensor on the liquid line after the condenser.
You should also check the relays, relay 1 is for positive supply to fan, relay 2 is for negative switching between full ground (high) and resistor ground (low), by default its always on low speed.
