AoA
Following is the MAF sensor reading of 1sz-fe engine on idle, engine was running with optimal temperature and in close loop.
Please suggest is it normal on idle or otherwise?
Jazaka ALLAH
any one please ?
This seems about the right voltage at idle.
Have you checkef mass air flow rate at idle through obd2 device?
Yes it shows 1.9 to 2.0 g/s on idle. i guess it should be 1.6 g/s for 1000cc car.
Not much to worry about. Its alright.
1.5v is normal at idle.
