Specifications
Body size:
Length / width / height (mm)
3810/1705/1540
Wheelbase (mm)
2460
Track (front / rear) (mm)
1472/1460
Curb Weight (kg)
1100
Fuel tank capacity (L)
40
Approach angle / departure angle
16.3/25.3
Luggage volume (L)
330/1100 (with rear seats folded)
Seating
5
Engine and transmission
Engine Model
GW4G13, GW4G15
Engine Type
Inline four-cylinder, four-stroke, water-cooled, dual overhead camshafts, aluminum VVT gasoline engine
Intelligent Engine Management System
Electronic anti-theft engine
Drive Mode
Front precursor
Displacement (ml)
1298
Maximum power (kW / r / min)
68/6000 (1.3L)
Maximum torque (Nm / r / min)
118/4200 (1.3L)
Transmission Type
MT / CVT
Vehicle performance
The maximum speed (km / h)
165 (1.3L)
Minimum ground clearance (mm)
138
60km isokinetic fuel consumption (L)
4.5L
Emissions
Euro Ⅳ
Chassis
Front Suspension
McPherson independent suspension
Rear Suspension
Longitudinal arm torsion beam suspension compound
Tire Size
185/65 R15
Brake type (front / rear)
Qianpanhougu Type / front disc
Steering Type
Hydraulic power rack and pinion
