Spec for the Airplane Tow Tractor
ENGINE OPTION 1
Manufacture...................................... Deutz
Model................................................. BF6M1013ECP
Type.................................................... Water-Cooled / Turbocharged and Aftercooled
Number of Cylinders........................ Six
Displacement..................................... 436.32 cu. in. (7.15 Lit.)
Horsepower........................................ 265 Hp (190 kw) @ 2,300 rpm
Torque............................................... 629.87 ft. lbs. ( 854 Nm) @ 1400 rpm
Min Idle Speed................................. 600 rpm
Max Rated Speed.............................. 2300 rpm
Flywheel............................................ SAE 3 Flywheel housing
ENGINE OPTION 2
Manufacture...................................... Cummins
Model................................................. C8.3-250
Displacement..................................... 506.49 cu. in. (8.3 Lit.)
Horsepower........................................ 260 Hp (198.36 kw) @ 2,200 rpm
Torque............................................... 825.98 ft. lbs. ( 1,11987 Nm) @ 1500 rpm
Max Rated Speed.............................. 2200 rpm
VW Touareg Specs
Engine: V10, 4921cc, 20v, turbodiesel
Max power: 356bhp @ 3414rpm
Max torque: 631lb ft @ 2776rpm
0 - 60mph: sub-7sec (est)
Top Speed: 140mph (claimed)
Now you think for yourself. this actually can be done by any vehicle, some just take more time then others.
