The Volkswagen e-Golf is getting ready to travel from Germany to the U.S., as the electric hatch is scheduled to make its North American debut at the upcoming 2013 L.A. Auto Show. Last seen at the 2013 Frankfurt Motor Show, the fully electric four-door hatchback hasn't changed much since then.
Motivating the front-drive Volkswagen e-Golf is a 115-hp electric motor with 199 lb-ft of torque, which allows the e-Golf to accelerate from 0-60 mph in 10.4 seconds. Top speed is limited to 87 mph, and depending on how it's driven, Volkswagen says the average range varies between 70 and 90 miles. For increased efficiency, the e-Golf is also equipped with Eco, and Eco+ driving modes, which pares back maximum power to 94 hp and 162 lb-ft, and 74 hp and 129 lb-ft of torque, respectively.
There are also three levels of regenerative braking sensitivity. The first Golf to use full LED headlights, the e-Golf also features C-shaped LED daytime running lights, which will be a new design cue exclusive to electric Volkswagens going forward. Blue trim in the grille also sets the electric car apart, in addition to aerodynamically optimized five-spoke 16-inch wheels. You'll also find hints of blue inside the cabin, where the e-Golf boasts a new instrument layout with a power display in place of tachometer on the left side of the wheel. The power display indicates if the motor is ready, the battery is being charged via regenerative braking, etc.
On the right side is the speedometer, which displays other important information such as the remaining charging time. As with other new electric cars, the e-Golf can gain back 80 percent of its capacity with a 30-minute charge. Standard equipment on the e-Golf includes keyless entry, push-start button, heated front seats, Bluetooth, leatherette seats, rearview camera, and parking sensors, while a touchscreen navigation system is available. Also new to the e-Golf is Automatic Post-Collision Braking System, which automatically slows the vehicle when it's involved in an accident. This new assistance system comes standard on the electric hatchback, and was implemented following studies that showed that about a quarter of all accident injuries are the result of a second impact. The system is designed to reduce the vehicle's kinetic energy after the initial impact, but can be overridden with application of the accelerator if needed.
