Size: 700 L/day = ~185 gallons/day, so pick an RO train rated a bit above that (a 200–300 GPD membrane or a small 300–500 GPD skid gives safe margin).
Must-have components (buy individually — common in local market & online):
Sediment prefilter (multistage)
Carbon (chlorine) prefilter
Antiscalant / softening step if hardness or high TDS (brackish)
High-pressure RO membrane + pressure vessel
Flow restrictor / concentrate flush arrangement
Post-carbon + remineralization filter (you must add this after RO)
UV (optional/extra safety)
Booster/high-pressure pump if feed pressure is low.
Pressure note (important): brackish RO needs substantial feed pressure (typical range for fresh/brackish: ~2–17 bar / 30–250 psi); if your well/suction pump can’t supply that, add a booster pump. Check pump working pressure vs membrane requirement.
Installation / plumbing: you can pump into your overhead tank — ensure tank is food-grade, has venting, and install non-return valve and float control to stop overflow.
Where to buy: local water-treatment shops, online marketplaces, and classifieds sell all individual parts (membranes, housings, booster pumps, filters). Prices vary — small booster pumps seen around ~₨6k–8k, and complete small commercial/domestic skids listed online (use those ads to gauge total cost).
Quick checklist before buying: measure TDS & hardness; confirm required membrane pressure; choose membrane GPD ≥ your need; add remineralizer; budget for periodic consumables (prefilters, membrane replacement, annual service).
