For Domestic Use Hydronix Water Technology Provides Best RO Plant in Pakistan. there are many stages in RO Plant which works as';
Stage 1 – (SED) Sediment Filter
The water passes through a high capacity polypropylene sediment filter. It’s a Sediment filter that removes all the larger particles up to 5 microns, including rust, dust and sediment.
Stage 2 – (GAC) Granular Activated Carbon Filter
For the second stage is a granular activated carbon filter. It also eliminates contaminants up to 5 microns. This is a pre-filter for the next stage. During the second stage the water gets rid of the unpleasant chlorine, foul taste and odor, colors and cloudiness.
Stage 3 – (ACB) Activated Carbon Block Filter
water goes through a Activated carbon block filter. It’s also a 5 micron filter that further removes any residual chlorine, taste and odor. At this stage the filter also removes the difficult-to-remove chemicals, including chloramines.
Stage 4 – (ROM) Reverse Osmosis Membrane
water is pressed through the heart of the Hydronix Domestic RO Plant – the high rejection TFC membrane with the micron rating of .0001 micron. This is the same technology that is used by companies in the production of bottled water. This NSF certified semi-permeable membrane effectively removes TDS (total dissolved solids), Virus , Bacteria , Lead, Arsenic, sodium, cysts, giardia, chromium, and a long list of other contaminants.
Stage 5 – (PAC) Post Activated Carbon
The final stage utilizes a finer PAC filter, which acts as a final polishing inline filter. As the water leaves the storage tank, this filter removes any left residual tastes and odors and makes the taste of water fresh.
Add on Stages for Hydronix Reverse Osmosis Plant
These Add on Stages can be added on customers demand.
Stage 6 – (BMB) Balance Minerals Ball
This filter improves the qualities of clean water by adding necessary Minerals for proper human development and health minerals, such as Calcium, Magnesium, Sodium, Potassium and others readily found in many natural mineral waters.
Stage 7 – (ABF) Alkaline Balance Filter for PH Balancing
The Alkaline filter changes the acidic RO water into a perfect Natural Alkali Calcium Ionized Water. The Alkaline filter simply gives back minerals such as ionized calcium, magnesium, sodium, potassium ion, which were taken away while purifying the water.
Stage 8 – (ANS) AntiBacterial Nano Silver
This filter Kill 99.9% all the remaining Bacteria’s & E Coli Bacteria Which is passed through RO Membranes.
Stage 9 – (UVS) Ultraviolet Sterilizer
We gives Money back Guarantee if you your water test repost rejected.
