First consult owners manual for oil recommendation in my humble opinion for Honda 70 liqui moly is to much to digest in terms of cost, Shell, Caltex, PSO, ZIC / Total with API -SG 20w40 or 20w50 is enough. Things to keep in mind
1. Always use Original Oil
2. Destory the Oil bottle after use (to prevent counter fetting)
3. Oil Change Intervel should as per Manufacturer specification
using Advanced oil in contrast to recommendation is may cause your engine to fail prematurely. As the engine is not design for that oil.
Advanced oil used to have low Phasphorus and Zinc which are the main lubricating ingredients
eg. API SG has more phasphorus and Zinc than API SL , using the oil below recommended level will cause engine oil to produce sludge i.e API SF has more phasphorus and Zinc then API SG grade oil
