Honda Valkyrie Rune
Engine Type 1832cc liquid-cooled horizontally opposed six-cylinder
Bore and Stroke 74.0mm x 71.0mm
Compression Ratio 9.8:1
Valve Train SOHC; two valves per cylinder
Carburetion PGM-FI with automatic choke
Ignition Computer-controlled digital with three-dimensional mapping
DRIVE TRAIN
Transmission Five-speed
Final Drive Shaft
CHASSIS / SUSPENSION / BRAKES
Front Suspension Trailing bottom link; 3.9-inch travel
Rear Suspension Unit Pro-Link with single shock; 3.9-inch travel
Front Brakes Dual full-floating 330mm discs with three-piston caliper
Rear Brake Single 336mm disc with two-piston caliper
Front Tire 150/60R-18 radial
Rear Tire 180/55R-17 radial
DIMENSIONS
Wheelbase 68.9 inches
Seat Height 27.2 inches
Dry Weight 794.0 pounds
Fuel Capacity 6.1 gallons
OTHER
Emissions California version differs slightly due to emissions equipment.
Rearview Mirrors Standard
Available Colors Candy Black Cherry, Double Clear-Coat Black, Illusion Blue
Model ID NRX1800
