Today cleaned the Radiator external area Used Kangroo engine cleaner and NASA Carb cleaner.
First sprayed kangroo and Sprayed Water as recomeneded on the bottle.
For some further cleaneing used Carb cleaner and then again sprayed the water as Carb cleaner is a bit oily.SO to avoid dust Spraying wather was necessary results were good and hopefully this cleaning will be enough for this summer
Also did a Little experiment Washed Urethene Air Filter with JOHNSONs Babay shampoo
lolz so far it looks good.Sumbuddy recomended to use surf but to me the particles of surf might block it further.
Though Washing it with petrol is also good option but Pressurized spray worth would try tht as well sumtime.
