Junoon is a good bike and almost VIBRATION LESS...very smooth...but way way overpriced...just for some plastic on it...you can also consider SPrinter in this regard...its more fuel efficient and more powerful but not soo sexy looks...but still ok...and its for just Rs 54800
and if you can add 4k more to ur junoon budget i.e approx 64k, then just buy a GS 125 which is 5 speed and theres no match for junoon...think abt it..
btw heres a comparison of sprinter,junoon and Cd 100:-
SPRINTER:-
Specification:
Engine Type 4 Stroke, Air Cooled, Single Cylinder, OHC
Displacement 109 cm3
Bore x Stroke 53.5mm x 48.8mm
Compression ratio 9.6 : 1
Carburettor MIKUNI BS22, Single
Starter System Kick
Transmisson 4 Speed Constant
Air cleaner Polyuretnane foam emelent
Cluctch Wet Multi Plate type
Primary Reduction 3.666 (77/21)
Final Reduction 2.500 (35/14)
Idle Speed 1,500 -+100r/min
Frame Type Sigle Backbone
Drive Chain 428, 102 links
Caster Trail 26/67 mm
Suspension Front Telescopic coil spring, oil damped
Suspension Rear Swinging arm coilspring
Brake Front drum
rear drum
Overall length 1,900mm
Overall width 755mm
Overall height 1050mm
Wheelbase 1225mm
Ground Clearance 165mm
Dry Mass 119KG
Tire front 2.50 -6PR tube
Tire rear 2.75 - 6PR tube
Fuel Tank 10.5 Litre
Ignition type Electronic Ignition (CDI)
Ignition timing 10 BTDC at 1,500 rpm
Dry Weight 91kg
Battery 12v9
JUNOON:-
Specification:
Engine: 4 stroke OHC
Displacement: 97.1cm3
Bore and Stroke: 50 x 49.5mm
Compression Ratio: 9.0:1
Fuel Consumption: 55 KM/L
Transmission: 4 speed constant mesh
Starting: Kick starter
Frame: Backbone
Ground Clearance: 160mm
Dry Weight: 86KG
HONDA 100:-
Specification:-
Engine 4stroke OHC cooled by air
Displacemnt 97.1cm3
Bore*Stroke 50*49.5
Compression Ratio 9.0:1
Clutch Weight contains different plate
Transmission Continous 4 speed mesh
Starting Kick starter
Frame Double craddle tubler type
Measurement 1983*735*1045mm
Ground Clearance 160mm
Tyre at front 2.75-18 6 PR
Tyre at back 2.75-18 6 PR
Dry Weight 98KG
