@Khan: If you have a good technical person as a mechanic for RX and GTO, than RX will be a comfortable choice, but do ask the spare parts shops and local bike freaks for a suggestions.
Did u had any negative thing in ur mind regarding ur bike?u should had go for it too;)
^^^ Its recently been planted with new work, still there are small small areas where it needs to be taken care ..... will observe her more for her response, with Blue Bird.... to see the work results.
RX main koi to bat aesi hay jis ki wajha sebaray baray gto riders jab rx ko samnay dekhtay hain to un ko vibration lag jati hay:D:D:Drx or gto ka comparison sirf wohi ker sakta hay jis nay dono bike 0 meter condition main chalai honlog 125cc 2stoke gto ko to bari asani se 115cc 2stoke rx se compare kerlaitay hain wahan un ko khyal hi nahi aata k hum 125cc ko 115cc se compare krtay haini tell u my experience dono bikes ka top end same hay but due to best pick rx takes the lead n lead(original bikes not altered ones)yehi wjha hay jab rx samnay aata hay to gto walay baghlain jhankna shoro kerdetay hain;)baki deciede @khanization bhai aap nay khud kerna hay jesa k main already keh chuka hon k dono bikes main se jo bhi bike aap ko behter condition main milay woh lay lo baki kisi help ki zrorat ho to we r here....@farhan he is a king of 2stoke he could also guide u better n best, where r u Farhan just come in;)
yes bro,frame and fuel tank,cylincer,rims are in original colour and rest of some are repainted.....
^^ No doubt,,,,, For this I say the best RED Rx115 of PakWheels and this thread is with Waseem.
@Khan: To make the bike like blue bird... is not that difficult for a person who knows the full line-up and technical points of the bike.
only one thing would bother;)the pocket;)
hahahhahaha......... True!!!!!!
But when we talk RX and GTO ------ we need to pull the pockets and Heart both :P:P:P:P:P
sure,
i have install the engine, and my bike is on idle runingengine specs arehead original 4Y2cylinder block original RXK135 (4Y2). size 1.00piston toprings top(npr)carburetor original RXK135(4Y2)clutch box RX115 crank bearings, Racing bearings with c ratingslower portion of engine is 19U-Y1(3M501)these r the specs of recently rebuillt enginethanks to all, for helping my to achieve thishope for the best
@Faheem RX main koi to bat aesi hay jis ki wajha sebaray baray gto riders jab rx ko samnay dekhtay hain to un ko vibration lag jati hay:D:'(
^^^^^^vibration^^^^^^^^ pa G ah gal kar ke tay vibration taaaaaaz ke diti jjjjjjjjjjjjjjjjjjj........
lolx pa g tuhano nahi khya c,u r still in good books lolx:D
@RX115aik baat to aap bhi man lo sir g GTO125 ki overall outL(H)(H)K ka bhi koi mach nahiiiiiiiiiii....in it`s mod & cc <label for="rb_iconid_5"></label>
faheem bro pics please
mainy inkar hi kab kia hy pa g gto has its own class n beauty but jab bat comparison ki aajati hay to dant taiz krna partay hain coz rx da jor e nahi koi:-#:D(H)
yar engine ki pics dekh k kya karo gyi will try to upload its video
sure waiting for it
right bro,but em having job and also single at the moment,no doubt em engaged but I can move with no tensions and spend from my savings....In comming months I will try to make her like Faheem and kamran want to see her.....
mainy inkar hi kab kia hy pa g gto has its own class n beauty but jab bat comparison ki aajati hay to dant taiz krna partay hain coz rx da jor e nahi koi:-#:D(H)[/QUOTE]
gru pa g dant taiz karwanay ke bad khali dant hi nahi dil or kalija bhi chahiya:o;):o
I had a gto 125 in original 100 size bore and bike was also in very gud touch...also used gto 110 but the word we use athri or badmash only fits to Rx as per my experience....
