Not used it..but its very old SG grade engine oil in market there are many other brands available with latest grades
Thanks.But YBZ manual and even YBR internationally recommends SG & higher.But SG suits the most with YBZ/YBR.
Latest the grades - thinner the oil.
YBZ/YBR engines are also very old. They make noise even on SL grade.
SG grades are cause to deposit carbon inside engine..so better to use some good quality engine oil with latest grade..in my opinion zic 4T oil will perform the best
Well. Your advice is appreciated.
Company manual mentioned SG or above.It means first recommended grade was SG when engine was manufactured.I will use SG & will update you bro.
Api SL make noises to the engine.
Regards,
I used Valvoline oil with 20ml oil additive liqui moly MOS2 -perfect engine voice - smooth gear shift & no clutch slippage.
I recommend it.
I am using Zic X5 SM grade a car oil in my bike from a long ago my bike has clocked 42k+ on this oil Alhamdolilah did not faced any kind of problem
Well good to know but why you didnt use oil specifically recommended for bike ? Any specific reason ?
In Car - engine oil & gear oil are DIFFERENT.In bike - engine oil & gear oil are SAME.
car engine oil can cause clutch slippage.
Aoa,I have YBZ 2020 model-
Jb bike gear m ho or stop karun to gear nai nikalty tb tk clutch ko thora release na karun.Ye problem just stop k wkt hoti ha - normally bike chalty wkt issue nai hota ha.
If anyone has an idea about it then plz guide.
JazakAllah
Have the same thing on mine. Probably clutch is a bit loose, i will be taking mine to a service centre once the situation gets better. Mine is driven just under 400 km at this point however this issue isn't regularly happening, it happens sometimes. My main problem is the chain which is probably touching the cover and making noise.
Bro i have used nearly all kinds of bikes oils..was not satisfied with them so shifted to zic X5 & found this oil far far better than any bike oil..engine gears clutch everything is butter smooth on this oil..after 42k+ my bike still do 120km/h...you can see in this video ring piston clutch plates bike is totally in stock condition
Adjust its Clutch to tight wards
Yes Im trying to adjust. Even at tight it has problems.
I think I also have to visit mechanic for this.
Can tight chain also causes such kind of issues?
before that I have YBZ-2019- I never faced such issue in it except neutral fails sometimes.
Might be loose chain has an issue with it, I tighten clutch infact experimenting by adjusting clutch on different levels. might be get perfect position.
or I will visit mechanic soon.
what about bike engine sound of Yamaha? does it reduce with current oil using by you?
If clutch problem is not solving by adjusting...then you might have to change your engine oil brand with some good one else..by doing this INSHA ALLAH your problem be solved
Bro first of all i don,t have Yamaha...I have GS150 & answer to your question all abnormal sounds from engine has been disappeared by using X5 oil...bike engine is super silent
Issue resolved ?How many kms drove ?
Still at 400km will call tomorrow and check if service center is open and take it there.
I drove 575kmsStill same issue
