I don't know it's current price as I got it back in 2010. Then it was 3000-3500rs.
It's better than others as it is without the fuse which other Chinese systems have. If you remove the unit the car would not start as removing these Chinese systems allows you to start the car if the unit is removed. It's not impossible to bypass it but it takes time as after removing the unit some wiring under the hood is to be changed.
There is a secret button which you have to press every time you start the car or open the driver's door as the car turns off after 90 seconds. I don't know if Chinese systems have this feature..
So I have found it better than others.
It's available at jail Road... Opposite to Ali motors is iqbal motors and you can get the system from the first floor of the building where iqbal motors is.
One thing kayes is not having is the doors lock with brake every time. It just locks the doors once itself after a few seconds. Rest you have to lock them manually when the car is started.
I have it in my two cars and it's running good since 7 8 years.
Hope it helps
