800-850 pe hota he idle , abhi ktna he?
start karo to 1000-1200 hota hai, quick heat up ho jati hai, t-valve or switch ki waja se phr 0 ho jata hai, ya max 100, isy kasy barha sakty hen?
RPM's with A/c
meri itni heat par iti hai to rpm zero ho jata hai
Tuning honay waali hogi.
ho sakta hai, but kisi ko idle way screw ka pta ho to shayad wahan se set ho jaty mainy kafi dhondha mila hi nai
IAC valve seem faulty
ab ye kon sa valve hai (A)
Tb (throttle body) mai hota hai IAC (idle air control valve) idle rpm ko stable rahta hai tb ki service karwaien agr masla hal na hoto IAC change karwai wese check light on hai kya?
Check light off hai, may b yahi masla ho, iska air filter khola hua tha, air filter huy bager ja rahi thi may b yahi masla ho.
Air filter ka bhi masla go sakta hai
Air filter change kar dia hai, but masla nai hal hua
BTW w-d40 aysy hi marun to kam kary ga ya khulwa k hi clean karwaon TB
Wd-40 nahi carb cleaner use hoga
Harib bhai agr ap ISB mai hi hai tou @car_bus2008 k sath diy kar Len
There's this one called rain x(most effective) . and cheapest is turtle glass Polish
meri 700 par hoti hai.
Did this last week, felt like sharing it because the results were decent,polished all exterior chrome /steel parts with brasso metal Polish.
Awesome results i must say , but dont you think rubbing them with brasso will remove the top protective coat?
Leaving my honest partner for a few days.
