Sorry i meant disc brake pads.
Also had radiator serviced and flushed with liqui moly radiator cleaner afterwards.. Added two litres of caltex coolant only to find out the water jacket was cracked and leaking, most likely due to radiator hose being removed unprofessionally..
I was so done with desi-mechanics and ustaads that i went to the dealership the next day to get everything done..
Its all good now, the difference between genuine disc pads and MK's is night and day and no more brake noises.. All in all it had to spend 31k on the periodic+100k maintainenece..
Here's a list of work done at 100k
Radiator service
Liqui Moly Radiator flush
2L Caltex Long Life Antifreeze
Radiator Cap
Radiator Rubber Mounts
Water Pump replaced although the old one blades found out to be just fine, it was starting to give minor noise.
New timing belt and tensioner bearing.
New A/C and fan belts.
TB sevice and Engine Tuning.
NGK Spark plugs.
Thermostat Cap and T-Stat Valve 92C.
Electrical System checked and Fuse Boxes serviced.
Radiator fan had electrical issue and one of the temperature sensors were not working properly causing the overheating and check engine light..
