Are you near fb area?
@abid110Not near FB but can go if mechanic work is satisfactory.Actually old mechanic has removed vaccum box and mess up related pipes. He is saying vacuum has no effect on engine performance so no need to reinstall it
Yes bro ... Tell me something about this coz. I jave installed a cold air intake in my carby cultus 2004 and felt a little bit more smoke in the mornig than normal
Everything inside the hood have some function they just dont know that
Cold air intake in carby cultus? It already has cold air intake from factory
Nop i removed that gitar type of drum of stock intake and placed a simple cold air intake of K&N
What you have done isnt a cold air intake by any means a cone shaped air filter (which doesnt filter anything anyways) isnt a cold air intake your car was breathing from a duct which leads to fender to ensure air it sucks is "cool enough" now it is breathing air which is warmed up by engine heat
What about installing a roof scope and fabricating an intake around it. Roof scope kaisa idea hai?
its good oil ..always buy from good running shop or pump...
but if u guys can add a little ....germans oils r better with only 400 rupees extra ....atleast they dont have issue with fake n real oil
if engine is new never use 20-50 ...i have seem alot of suzuki recommending 20-50.... use atleast 10-40
@ibne.ali.18Can u send pictures of your modified air intake to understandBTW no one has recommended Mechanics expert on cultus
You have carb cultus or efi?
@trouble_makerMine is Efi Cultus
I wanna share the pick here... But cant attach file
No idea about Karachi brother , i live in Lahore
Salam all members, i m facing an issue related to hood lock everytime after visiting my village mean to say after experiencing some jumps etc i find my hood opened on first lock not completely opened how can i fix that?
Check the wire yourself and see if the hood opening lever is on its place (Not opening the hood) or Get the lock adjusted from some denter etc. he will hardly take rs 100
Kia hal hai Sab ka.
lock needs adjustment
ALHAMDULILLAH fine , how have you been buddy?
