Lol
weather of Lahore is unpredictable these days and rain every now and then . Waxed the car 1.5 months ago and still wax is going strong
DO NOT use elfy on painted surfaces . it will be your worst nightmare if you change or remove the air press . use good quality silicone tape for the purpose . believe me . it is STRONG . and no air press will be flying in the air . the discussed tape is almost 40RS/ft
What about the double tape which is already on their back ?
stick them with the original tape once . if the tape performs good then leave it . else remove the airpress and tape. apply new tape and re-install them . .
Right
Expect anything between 5.80 to 6.30.the market of cultus is very UNPREDICTABLE, wherever you find a good offer, you may give it away
Guys, is it me or the sound system in our cars really sound better when we are riding vs when the car is still ?
i have installed front speakers in dash , rear speakers on parcel shelf and a sub . the quality of sound is really good . as for the riding vs stationary part . maybe your cars engine noise is disturbing the sound from the speakers when stationary . I will suggest installing front speakers in the dash . so the distortion/engine sound is not so dominant
Noticing more than usual petrol smell from the silencer, what's going on ?
can you please share a picture of your setup ! how is your sub installed on parcel shelf, is it blocking the rear view ?
Mixture settings may be, not all the fuel is burning properly.
Is it possible, mixture screw may be loose so it goes bad on its own due to engine vibration? Cause mixture once set should not create problems for quiet sometime i think
MashaAllah beautiful Cultus . Very informative and updated thread
loose screw can be the one of the reason but more often clogged or dirty air-filter,or any other blockage in air-inlet, faulty injector or air flow sensor in efi may be,bad spark-plugs, thermostat stuck open can be a cause.
How long spark plugs last ? Single tip
Manual says 20,000 to 30,000 I guess, and mechanic says after 12,000 or 15,000 kilometers. iridium plugs lasts much longer. I'd say its better to take the plugs out, and let their condition decide.
obviously it blocks the rearview mirror . but the sides are visible and half of the middle part is disturb which is not so disturbing . the enclosure is smaller one .
Thanks brother . its not one .but a bunch of beautiful cultuses keeping the thread alive and informative
unburnt fuel . most probably a fuel re adjustment . or it can also be plugs . is there any black smoke too on revving ?
