I m asking for cd 70
Guys i need ur recommendations regarding gear oil change
You will have to check with bike electricians and shopkeepers. I am using stock headlight with the good quality bulb ( as claimed by electrician) and it serves the purpose .
According to the manual suzuki GL4 SAE 90 gear oil should be used . Quantity is ~2.5 liters. Tranmission oil should be changed every 40k kms
Quantity is 2.2 litres old cultus told by some senior, mechanic pour 2.5 litres. Efi requires 2.5litres
How much to put in carby?
Guys, which engine is there in carby cultus, interference or non-interference? If timing belt breaks will it damage the engine? If its non-interference then there should not be any damage as far as i know.....anyways what do u say?
2.2 litre gear oil, some seniors say that gear oil is not completely drained when changing hence it may require even less you can check it by opening the filler nut when it will overflow then stop pouring more oil.Will damage engine IF broken according to my knowledge my mechanic said it will sieze engine if broken while running.
Bro check your gearoil level by filler nut if its overfilled then reduce it otherwise your gear seals will start to get damage... Just my 2 cents
I think we should drain and fill from speedometer nut
No we will eventually overfill or underfill.... Fill from gear oil filler nut, which is meant for that purpose... Car should be balanced before.
Before
Engine Degreaser Applied
Same condition my tappet cover is also leaking thinking about changing the tappet cover seal and applying good quality silicon or should i use as it is?
Where to buy this engine degreaser n how to use it n how often?
The product used was Nanoskin Homerun . You can get it from ahmadyarautospa. Just spray on cold engine . Agitate with a brush and wash off with water .
Tappet cover seal should be changed . As oil seapage is not good . I will also go for tappet seal replacement after eid holidays .
Leakage was same like yours... Can be seen on tappet cover...will change it soonWhats the cost of this product no harm to distributor?
