Hello Readers,
Base Motors has introduced Tire Pressure Monitoring System for safety and performance of your vehicle.
A tire-pressure monitoring system (TPMS) is an electronic system designed to monitor the air pressure inside the pneumatic tires on various types of vehicles. The system is also sometimes referred to as a tire-pressure indication system (TPIS). These systems report real-time tire-pressure information to the driver of the vehicle, either via a gauge, a pictogram display, or a simple low-pressure warning light.
TPMS is a set of Transmitters and Receiver. The measurements of pressure and temperature are then sent via a wireless radio-frequency transmitter (Sensor in your tires) to a receiver (monitor), which analyzes the signal and reports the results on a monitor mounted within the cabin of the vehicle.
According to survey, 99% people in Pakistan does not know what is the right pressure of your Tire and When. Right pressure of all the wheels are set by the car manufacturer and is mentioned on the leaflet and by rule of thumb, it is about 33 Psi. Also the pressure mentioned or which we maintain in tires are not correct, as we pressurize the tire when the air is hot and the present pressure is already increased, right pressure is always when the tire temperature is cold. You can read the rest in Base Motor’s FAQ on the website.
Use of TPMS is not just for monitoring your tire but give the below mentioned benefits,
1: Early Warning of Low/High Pressure, low/high pressure damages your tire strength and a risk of tire burst.
2: Early Warning of Tire condition will enable you to protect your vehicle from any accidents.
3: Early Warning will give you protection of unwanted flat tires, your precious time in case of flat tire and provides safety for your entire family.
4: Managing right pressure not only prolongs Tire's life but makes your vehicle consume less fuel and less CO2 emission to the environment.
Base Motors, are introducing 2 types of Tire Pressure monitoring System,
1: Ave Color TPMS - Made in Taiwan - Introductory Price, Rs. 16,500/=
Note: Ave TPMS also monitors car's Battery Voltage and alarms you in case of battery getting weak, etc.
2: Royceed Black and White TPMS - Made in China - Introductory Price, Rs. 13,500/=
Above Products comes with 1 year Warranty. For more information on the products visit our website, Base Motors or call on below Mobile Numbers,
Babar Naseer
0333-2249770
0345-2960485
Base Motors.
