@op. its a problem with low idle and low vacuum. on cng...the engine is not able to make enough vacuum.
so there is very less vacuum going to the break booster. it feels as if you are pressing the breaks when the car is not started.
what you need to do is get a vacuum pump installed in the vacuum like to the break booster.. and that will solve your problem instantly
