I did this because vitz was having severe vibration in gear d since i bought this car about 4 months back. Did every thing but nothing works. everytime mechanic charge around 2000 rupees for cleaning the TB and after that saying you need to change this and that. I already spend lot of money for sorting out this issue. changed everything (Irridium plugs, TB 3 times, OEM Air Filter, OEM Oil Filter, Engine mounting, harmonic Fuel injection cleaning, change different oils, Voltage stablizer, alternator. but nothing works. So i decided to do it my self everything. I go though many forums and 1kr fe technical manuals. I have not cleaned MAP sensor only but O2 sensors and washed each and every connector with NASA carburetor cleaner. I was fedup and did it my self. But results are coooooooooooooool.
Thanks you so much wasay. I did the same. great tip for marking coolant pipes before removing them.
Thanks ngen. I did that after reading your post. Yes i am having a bad fuel consumption. So hoping that for now onward the fuel consumption will be better. Once again Thanks a lot.
