Guys I bought a vitz a week or two ago. 2002 FL package etc and the problem is this.
I got the car and started driving on AC and all and it started to heat up after maybe 30 minutes. The radiator water was all boiling and I received the red light in the meter etc.
I said fack it and drove around without a/c for a week. No problem at all, car was not heating up and it was all good. I did see the engine check light for some reason.
Fast forward to this week. My that was driving the car without A/C, maybe went like 8 KM and the car was heating up, showed it to a mechanic and he said the fan aint working. So he disconnected the horn wire and ran the fan directly, so it starts when the switch is turned on.
Now for some reason, I have no idea, the Green sign that shows up that tells you the engine is cool won't go away. And the check engine light is there constantly as well( as it was before).
Sooooo..
Do you think the check engine light was there because the radiator fan was not working? And instead of having it connected directly if I go ahead and fix the fan issue both the constantly cool engine light and check engine light will magically go away? ( I hope)
What the ****, I bought this car so I wouldn't have to go through this crap and now this.
ALso, does the radiator fan in vitz normally start only when its needed?
