Results 1 to 5 of 5
Thread: Vitz Vibrations
    shoaib.nabeel's Avatar
    Feb 2013
    34
    29
    dynamicallyStatic's Avatar
    Jul 2008
    Rawalpindi
    35
    1,290
    5
    138 Post(s)
    2 Thread(s)
    @shoaib.nabeel
    Ref to your *Engine surging*:
    I have a vitz 08 and at very low speeds (around 20kmph), I feel that if i lift the acceleration pedal the car kind of tries to slow down itself (giving a slight jerk). To mantain a slow speed of 20-25, I have to keep the slight pedal pressed. My understanding is that it should keep the momentum on a flat track if i lift the pedal.
    Also, the same behavior is experieced when I am at high speeds (60-70) and apply brakes sloftly to slow down, upon reaching 20-30, it gives that slight jerk again and slows down quickly...
    Not sure if this is an intended feature?
    Changed spark plugs recently, air filter is clean, throttle body is clean.
    Feb 2013
    34
    29
    Jul 2008
    Rawalpindi
    35
    1,290
    5
    138 Post(s)
    2 Thread(s)
    No overheat, no check engine light. Have taken it to motorway as well, no issues. The issue is only with very low speed as i stated in my query.
    amjads98's Avatar
    Jun 2009
    Rawalpindi
    41
    102
    4 Post(s)
    no issues with your car. its normal.
