Results 1 to 2 of 2
Thread: Electrical issue with My Vitz 2010
    hammadsiddiqui1976's Avatar
    Jul 2010
    244
    3 Post(s)
    Default Electrical issue with My Vitz 2010
    I was out of country, and after 04 months when i try to start my Vitz 2010 found no response like (dead).
    i immediately remove battery and connect with UPS to re charge.
    after 4 hrs, i connect my battery with terminal, immediately indicators lights on which are in headlamp.
    when i removed (-) terminal lights switched off.
    then i again connect the terminal with with battery, again indicator lights on, then i try to switch on ignition but no response and no Dash indicator signal was blinked.
    kindly help before i go to any Electrician i want to know my self about problem.
    thanks
    Jul 2010
    244
    3 Post(s)
    no response very surprising!
    any way i have resolved the issue
