Page 1 of 2 12 LastLast
Results 1 to 20 of 27
Like Tree3Likes
Thread: Vitz 99 Break issue on AC
    malizahid's Avatar
    Jun 2009
    31
    6
    Default Vitz 99 Break issue on AC
    Salam ,
    I have vitz 99 with CNG installed . Recently i am getting 2 major issues in my car .
    1.RPM gets too low specially on AC and car engine gets off almost on every signal .frequency in petrol is low and on cng its always .
    2.Breaks almost doesnt work on AC with petrol and cng both . This happens specially when the car is running at a low speed .
    I have checked couple of mechanics but dont get any satisfactory answer . There is one famous Guddu mechanic in tariq road who is saying its due to engine weakining and if you change only the engine assembly this will be solved .
    He serviced throttle body and also changed choke sensor to adjust the RPM . Also tappets are checked and they are not tight .
    Another mechanic from toyota motors is on a suggestion that it is nothing with the engine , there is something electrical fault
    Please give your experience only those who have faced similar problem and also how this was solved .
    Also if anyone knows some expert mechanic to fix this . Kindly provide his address and contact no .
    Waiting for your answers anxiously .
    s_mizba's Avatar
    Jan 2004
    35
    625
    same problem with my friends platz
    saboor73's Avatar
    Oct 2013
    10,553
    25
    351 Post(s)
    14 Thread(s)
    6
    25
    The person who designed the vaccum lines of 1 gen yaris/vitz/platez was a drag additic its common problem with 1sz stupid vitz get them inspected for leaks @abid110
    abid110's Avatar
    Jan 2014
    3,894
    90 Post(s)
    Quote Originally Posted by saboor73 View Post
    why me? i dont own one!
    saboor73's Avatar
    Oct 2013
    10,553
    25
    351 Post(s)
    14 Thread(s)
    6
    25
    Quote Originally Posted by abid110 View Post
    You once asked that how vitz first gen is
    abid110's Avatar
    Jan 2014
    3,894
    90 Post(s)
    haha yes i remember
    margallar's Avatar
    Oct 2009
    9,958
    6
    283 Post(s)
    4 Thread(s)
    This
    Check the vacuum pipes for leaks
    But
    Shutting off on ac is probably an electrical problem.
    Brakes seem like vacuum issue
    haters gonna hate, potatoes gonna potate
    saboor73's Avatar
    Oct 2013
    10,553
    25
    351 Post(s)
    14 Thread(s)
    6
    25
    Quote Originally Posted by malizahid View Post
    There is one famous Guddu mechanic in tariq road who is saying its due to engine weakining and if you change only the engine assembly this will be solvedsolved
    Vitz 99 Break issue on AC - images?qtbnANd9GcTZBQmhc0qjkr28omvWlvBonk2zpHJ98LtzsOBLKhJjc2wJFmmSe t7iqt02Q
    abid110's Avatar
    Jan 2014
    3,894
    90 Post(s)
    hahahaha good one
    margallar's Avatar
    Oct 2009
    9,958
    6
    283 Post(s)
    4 Thread(s)
    Ustad ko compression tester ni chaiye...ustad ko injun ki chaal sey pta lag jata hai...
    Sent from my SGH-T989 using Tapatalk
    saboor73's Avatar
    Oct 2013
    10,553
    25
    351 Post(s)
    14 Thread(s)
    6
    25
    Quote Originally Posted by margallar View Post
    Compression test for such ustad is angerzo k chuchele
  12. #12
    malizahid's Avatar
    Jun 2009
    31
    6
    Can be this a vacum sensor issue ?
  13. #13
    Majidkhan567's Avatar
    Dec 2012
    413
    2 Post(s)
    same issue with my vitz
  14. #14
    naqviali's Avatar
    Oct 2006
    Quetta
    45
    40
    2 Post(s)
    For the very reason sold my ride. Couldn't get it fixed.
  15. #15
    saboor73's Avatar
    Oct 2013
    10,553
    25
    351 Post(s)
    14 Thread(s)
    6
    25
    Quote Originally Posted by naqviali View Post
    You didn't visit good mechanics than its hardly 1 hour job
  16. #16
    malizahid's Avatar
    Jun 2009
    31
    6
    Can someone tell me good mechanics in karachi who can fix this issue . Prefered areas near baloch colony / tariq road / saddar . Please provide their names and contact numbers .
  17. #17
    malizahid's Avatar
    Jun 2009
    31
    6
    Still the actual issue is not discovered . Can someone help me ?
  18. #18
    sirdneo's Avatar
    May 2013
    84
    4 Post(s)
    Salam ,
    On petrol issue is due to dirty Throttle Body and MAF sensor, get both of them cleaned and your RPM issue will be solved.
    On Cng, it happens due to less gas , you have to open little more gas if you want to drive on AC, it will consume extra gas and your gas milage will go down, but hard break and engine shut down can be very dangerous so you have to compromise this on gas consumption.
  19. #19
    malizahid's Avatar
    Jun 2009
    31
    6
    Thanks for your reply . I have already serviced throttle body and have replaced choke sensor , dont know about MAF sensor . As far as breaks are concerned , even on petrol and on ac breaks gets hard and doesnt work . More interestingly breaks get more hard when i am driving slowly on ac . When the speed is fast , breaks do work and they get little hard but not as good as without ac .
    Any suggestions ? still its because of low RPM breaks does not work ?
  20. #20
    asad1's Avatar
    Aug 2005
    30
    2,707
    3 Thread(s)
    Whats the mileage of car seems like Ur car is losing compression engine assembly change kro *** to book pay b new no. Dalay ga 22k kind assembly Milay ge is se behtar hai rebuild krwalo 15k tk kharcha hoga
