Helo guyz..i have vitz 2010 bought recently driven 58k km originally..when i drive , there is a sound like (grr,grr) came from gear..seems that there is a vibration in the gear and very irritating sound from gear. Also when i slow down the car for U-turn or for speed breaker , it seems that the car stops and the gear is not shifting properly and the car loose smoothness..i have checked my car from toyota sahara and also from auto gear specialist in Gulshan ravi lahore.He say that probably your bearing in the CVT gear occuring problem and the replacemet of that bearing will solve the problem.can anyone having the same problem?or can anyone suggest should i replace the gear or repair this one?
Anyone help?
Get this on repaired under 10k expense if they quote you more than that then find a good swap for the transmission in less than 20k.
He charges me Labour=5000Gear Bearing = 4000Gear oil CVT 6 litres = 6000Total = 15000
Make Sure Its The Bearing Not Transmission Gears Or Drive Mechanism Inside CVT Itself....
CVT Are Precisely Built And Need Expertise To rebuild One...! Usually Replacement....
So Make Sure Your Spending's Dont Go Into Drain
Best to get a second opinion as to what it is, and if you plan to keep it and this is some major work, look for a another gearbox
Dont use toyota original cvtf after repair instead of that use kixx cvtf fluid will cost you 2800pkr per 4 liters.
