Hi,
I serviced cvt (T410) including torque valves,filter and oil when car was 40,000 kms. now when car is 45,000 what oil pressure should I expect. I measured this by logging the oil pressure pid
I am getting the following with cvt temp of around 35c (cold engine)
On Park I get 350 psi at 1500 rpm
On Reverse (with break pedal pressed) 0 psi
On Neutral I get 285 psi at 1500 rpm
On Drive (with break pedal pressed) 0 psi
Whilst driving the car (cvt temp around 70c) I get
400 psi at 1500 rpm
520 psi at 2400 rpm
1100 psi at 4500 rpm
what is your opinion please ?
