Results 1 to 11 of 11
Thread: vitz 2005
    capricornaz52's Avatar
    Oct 2016
    6
    Default vitz 2005
    today my vitz 2005 started giving huge amount of white smoke from silencer, on accelerating at parking.as soon as i push the accelerator for a few seconds a large amount of white smoke comes from the silencer ,please do guide me that what could be the problem?
    walls's Avatar
    Feb 2010
    30
    215
    2 Post(s)
    Was it all sudden?
    Or you just noticed it today?
    Recent oil change?
    Sent from my GT-I9192 using PW Forums mobile app
    Oct 2016
    6
    i notced it today i think so
    i went t mechanic today and the mechanic told me that it engine problem and the assembly will have to change
    is it right
    Oct 2016
    6
    oil changed was 4 months before
    Oct 2016
    6
    sir i m wai8ing for your rply.do guide me wats that and what to do
    walls's Avatar
    Feb 2010
    30
    215
    2 Post(s)
    @spiderman
    Please guide him something
    spiderman-17's Avatar
    Jun 2016
    106
    6 Post(s)
    Quote Originally Posted by walls View Post
    @spiderman
    It can be many reasons and hard to guess without seeing the car, he did not even mention engine type and milage
    I would start by checking pcvalve because it's easy to clean/fix, then scan the car for error codes. And move on to compression test when engine is hot. It could also be a rich fuel mixture or a choked catalytic converter or a bad sensor
    walls's Avatar
    Feb 2010
    30
    215
    2 Post(s)
    Quote Originally Posted by capricornaz52 View Post
    You must start things to be checked as guided by spiderman before going to a major engine overhaul
    Oct 2016
    6
    thanks for conserning,
    how to do compression test
    and how to clean a catalic converter
    Vaqas1's Avatar
    Nov 2004
    5,267
    6
    49 Post(s)
    First of all how much kms car did with this oil? Try changing oil to 10 40w oil grade. See if that helps. Compression test needs to be done to confirm.
    Sent from my HUAWEI VNS-L21 using PW Forums mobile app
    Speed costs money, how fast can you afford to go.
    spiderman's Avatar
    Feb 2005
    9,667
    52 Post(s)
    7 Thread(s)
    @spiderman
    you tagged wrong person
