Results 1 to 6 of 6
Thread: help me for my car suspensions plz..:(
    aleemhaiderlaghari's Avatar
    May 2014
    Hyderabad
    27
    14
    Default help me for my car suspensions plz..:(
    Salam..
    I have bought new Wagon R but i am facing a problem that its too much bumpy, its too uncomfortable on rough and bumpy roads and off roads.. why it so ? even my old Cultus 2005 model is smoother on these rough roads.. why this happends is New Wagon R.. is there any suspension prob or shock absorber probs altough its new car it should not be as much bumpy.
    rep
    Click here for SOLUTION
    john0995's Avatar
    Jun 2008
    Hari pur
    1,532
    17 Post(s)
    I am not an expert but I think its bcz of tires. wait for some expert reply
    CoMmiNg SoOoOoOoOoOoOoOoOn
    May 2014
    Hyderabad
    27
    14
    tires how and why ?? The stock tires of Wagon R was too small 144/65 R 13 with alloy rims but i have replaced them and bought 175/70 R 13 with Alloy rims.. does these tires make prob to bumpy car??? rep
    May 2014
    Hyderabad
    27
    14
    i have put 28 psi pressure in all 4 tires does this pressure make some prob ??
    abzia's Avatar
    Oct 2006
    32
    337
    10 Post(s)
    It is recommended to stay within 3% of OEM tire size, whereas you've exceeded OEM tyre size by around 10.8% (shall put extra load on engine too). Additionally your speedometer will show speed 10% less than you are driving at.
    Even if it is not good for your car, it shouldn't be bad in comfort IMO with mere 28 psi.
    If loaded, the tyre might touch wheel arch and become a safety hazard. This out-spec'd tyre might also rub when steering is fully turned to one side.
    May 2014
    Hyderabad
    27
    14
    abzia then what size range should be acceptable for my vehicle ?? do i change my car tires and what size and diamensions?? bcz 145/65 us small nd narrow for this car What is 3 % OEM for me dear ? And how much psi pressure should i put in each tires rep
