Asalamoalaikum.few days back somebody marked 2 deep and nearly 8 inch long scratches on my car's door.please help me out with a solution for removing it. Thank you.
Sent from my GT-I9505 using PW Forums mobile app
these are not deep.
spray water on the scratch, using spray bottle or a dripping wet cloth, if the scratch goes away then its only clear coat scratch and original paint is intact.
if the scratch still persists then it is too deep and may need a professional paintjob OR qalam.
Use formula1 scratch-out and micro-fiber cloth and rub it thoroughly, this will eliminate the scratch for the most part without being majorly agressive.
Use chemical guyz swirl and scratch remover compound. Its good.Use ur nail to check the depth of ur scratch. If paint is missing then u will fell the gap while checking
Sent from my iPhone
Use compound(formula one scratch out) and rubbing with soft cloth with bit pressure alongwith spraying water....it will be gone inshaaaAllah
Sent from my HUAWEI VNS-L21 using PW Forums mobile app
