0B-2 MAINTENANCE AND LUBRICATION
Maintenance Schedule
Maintenance Schedule Under Normal Driving Conditions
NOTE:
[LEFT]This interval should be judged by odometer reading or months, whichever comes first.
[B]•
[/LEFT]
This table includes service as scheduled up to 90,000 km (54,000 miles) mileage. Beyond 90,000 km[/B]
(54,000 miles), carry out the same services at the same intervals respectively.
Interval
Km (x 1,000) 15 30 45 60 75 90
Miles (x 1,000) 9 18 27 36 45 54
Months 12 24 36 48 60 72
ENGINE
Drive belt
– – I – – R
Valve lash (clearance)
– I – I – I
Engine oil and oil filter R R R R R R
Engine coolant
– – R – – R
Exhaust system
– I – I – I
IGNITION SYSTEM
Spark plugs When
unleaded
fuel is used
Vehicle without
HO2S
Nickel plug
– R – R – R
Iridium plug
– – – R – –
Vehicle with
HO2S
Nickel plug
– – R – – R
Iridium plug Replace every 105,000 km (63,000 miles) or
84 months
When leaded fuel is used, refer to
“MAINTENANCE RECOMMENDED UNDER SEVERE
DRIVING CONDTION
” in this section.
FUEL SYSTEM
Air cleaner filter Paved-road I I R I I R
Dusty conditions Refer to
UNDER SEVERE DRIVING CONDITIONS
in this section.
Fuel lines and connections
– I – I – I
Fuel filter Replace every 105,000 km (63,000 miles)
Fuel tank
– – I – – I
EMISSION CONTROL SYSTEM
PCV valve Vehicle without HO2S – – I – – I
Vehicle with HO2S
Fuel evaporative emission control system – – – – – I
NOTE:
[B]• “
R” : Replace or change[/B]
[B]• “
I” : Inspect and correct, replace or lubricate if necessary[/B]
For Sweden, items with
✱ (asterisk) should be performed by odometer reading only.
[B]•
For spark plugs, replace every 50,000 km if the local law requires.[/B]
[B]•
Nickel spark plug : BKR6E-11 (NGK) or K20PR-U11 (DENSO)[/B]
[B]•
Iridium spark plug : IFR6E11 (NGK)[/B]
MAINTENANCE AND LUBRICATION 0B-3
Interval
BRAKE
Brake discs and pads (thickness, wear, damage) I I I I I I
Brake drums and shoes (wear, damage)
– I – I – I
Brake hoses and pipes (leakage, damage, clamp)
– I – I – I
Brake fluid
– R – R – R
Brake lever and cable (damage, stroke, operation) Inspect at first 15,000 km (9,000 miles only)
CHASSIS AND BODY
Clutch (fluid level, leakage)
– I – I – I
Tires (wear, damage, rotation) /wheels (damage) I I I I I I
Suspension system (tightness, damage, rattle, breakage)
– I – I – I
Steering system (tightness, damage, breakage, rattle)
– I – I – I
Drive shaft (axle) boots/Propeller shafts (4WD)
– – I – – I
Manual transaxle oil (leakage, level) (I : 1st 15,000 km only) I
– R – – R
Automatic transaxle fluid Fluid level
– I – I – I
Fluid change Replace every 165,000 km (99,000 miles)
Fluid hose
– I – I – I
Transfer oil (4WD A/T) (leakage, level) I
– I – I –
Rear differential oil (4WD) (leakage, level) (R : 1st 15,000 km
only)
R or I
– I – I –
All latches, hinges and locks
– I – I – I
Power steering (if equipped) I I I I I I
NOTE:
• “I” : Inspect and correct or replace if necessary
Look this the maintenance scheduel of suzuki liana from its manual,here clearly mentioned that brake oil should be changed after every 30k kilometers,if your car's oil is short then no need to change it,just pour some more brake oil.
