@shami you are the best inspector of your car as she belongs to you..
You are requested to refer to the Maintenance Schedule (Page no: 121) provided in the Owner’s Manual of your car.
Mostly these things are included.
1--------------get the tappets adjusted if needed
2--------------throttle body cleaned
3--------------gear oil change
4--------------plugs changed if needed
5------------brake pad changed if needed or adjusted
6------------ If engine oil need to be changed along with oil filter.
7------------ Check air filter if need to be replaced.
& yes go to Honda and dont sit in the coffee area while reading news paper stay on their A$$ and no1 will cheat you , thats what I do
Good Luck
