TO CIVIC 007
BROTHER YOUR CAR MIGHT BE A SPECIAL EDITION CIVIC OR YOU MIGHT HAVE GIVEN FULL ACCELERATOR AT STARTING TIME OF 0-100 KMPH WHICH ISN'T THE CORRECT WAY OF CHECKING OUT THE 0-100 KMPH TIME OF VARIOUS CARS
AISA KARNE SE CAR SUDDENLY 0-40 TOUCH KARTI HAI EVEN IN LESS THEN 1 SECOND
IF YOU WANT TO CHECK YOUR CAR'S ACCURATE 0-100 KMPH TIME SO DON'T GIVE FULL ACCELERATOR AT THE STARTING POINT
GIVE APPROPRIATE ACCELERATOR AT STARTING TIME AND THEN RELEASE THE CLUTCH AND THEN GIVE FULL ACCELERATOR AND SHIFT GEARS AS FAST AS YOU CAN
THE ACCURATE 0-100 KMPH TIME OF THE STOCK 2005 CIVIC VTI IS 9.5 SECONDS AND THAT OF THE NEW STOCK CIVIC 1.8 IS 9 SECONDS LEKIN AGAR TUM START MEIN HI APNI CAR KO TEZI SE UTHAAOGE TOH PHIR TOH CIVIC VTI 1.6 WILL DO 0-100 KMPH IN 8.5 SECONDS AND THE 1.8 WILL DO IT IN 8 SECONDS BUT THAT ISN'T THE CORRECT WAY!!!
SO DO TRY IT NEXT TIME WITH THE PROPER WAY!!!
