Results 1 to 4 of 4
Thread: YAMAHA DENONYCHUS 2007 PICS..
    s3rialkill3r1's Avatar
    Mar 2006
    28
    2,562
    Default YAMAHA DENONYCHUS 2007 PICS..
    Yamaha Deinonychus Concept
    Taking advantage of two in -wheel motors to free up space around this electric motorcycle's frame, Yamaha installed a pair of electrohydraulic pistons that work in concert with extendable front forks to allow this bike to change its shape based on application. Fully extended, the pistons lengthen the chassis for cruising; when compressed, the pistons pull the wheels closer together and increase ground clearance for off-road tomfoolery. The two rocket-booster-looking canisters on the back are batteries, and the Deinonychus is designed to accommodate up to four of them depending on whether the rider would rather skim weight or ride for longer.
    YAMAHA DENONYCHUS 2007 PICS -473673
    ))))ROCK KARACHII ROCK!!!((((
    Mar 2006
    28
    2,562
    SAMAGH SAY BAHIR BIKE HAI..
    c123pk's Avatar
    Apr 2005
    40
    12,622
    10 Post(s)
    class ki bike hai !
    Mar 2006
    28
    2,562
    YAAR WHR IS THE ENGINE?
