i am not sure if its even heating up or not, it had thermostat issue or dont know what,got zic's coolant pre diluted,poured 4 litres,no water,that day its fan stopped working dont know what they did or what happened,i didnt used to keep eye on temperature needle n at night in parking i saw steam coming from bonnet,saw needle,it was quite up high,mechanic checked,all coolant was gone :o
after that it was heating up only at high rpm's like 5-6 on engaging vtec
so got gasket changed,head faced,radiator cleaned leaving no possibility of heating up again n now dis madness came from no where :S
n every time i went to show it to him he said everything is fine n it was at that time
tried another experiment now,same route,again on that incline,this time i kept rpm at 2.8k rpm,reached top,saw needle it was above middle slightly,then came the signal on which i was in bike's lane,just wanted to get ahead,but first gear shifted at 4k,second wid normal race at 3k,after that slow,needle didnt moved,after that on way back,again tried 2-3k shiftings n needle stayed at same position,no gear down or sudden race,seems some issue of uphill or of needle abnormality,i guess will go to that mechanic trying some quick race wid needle already high so he can see for himself n attach obd scanner to see if its some sensor going crazy
