So much request for Navigation Programming Discs solution so am offering this service for ALL Navigation Systems. Please post your Radio model and contacts.
esclipe player but i am unable to use its navigation and also it language is japense or chinese
My model is eclipse avn f01i . I need its map disk in order to make it work. Please help
Maddyboy, you need to be more specific on what the issue is....if the problem is that u want it in english I don't do that BUT if its a case where u did a battery pull and you can't use the player anymore I can bring it to its working state in japanese...you could post a picture of the error and also tell me the model...
thrm, this model uses SD card so all the map files are stored on the SD instead of a card which is recovered a little different from normal. Could you post a pic of the error on screen?
Well the navigatiom is with my frd and the battery wplugs were removed from then onwards its asking for its map disc . What should i do. It was working when it came from japan
Just help me bro somehow i need its file. This all messing up happened when battery was disconnected
This isn't as easy as you think bro I need to see the error message you are getting. Are you seeing this "Please insert correct map sd card"?
Where are you located i changed battery of my accord CL9 now getting this error
Yeh i am getting the error u mentioned
salamneed software for eclipse avn 1106d mkiii m getting this error
thnx
Great service you are providing. I own a UK spec Honda Accord '04, do not have it's Navigation DVD with me and haven't had much success with the local vendors so far. Error message being "please insert dvd". Contact number 0300 9445577.
Salam, panasonic strada CN-R500D ... SDHC needed, possible ?? Thanks
aOa, have this unit in my Prius, it also have map SD card with Japanese maps only can we change its language and can we install Pakistani map in this??
Conversion to english and change of navigation is not possible CLICK ME
Well, I have installed this Chinese unit having Pakistani maps/Navigation, DVD, Bluetooth, aux, etc. Maps e just like Honda Navigation unit, sound quality is reasonable.
hi guys i bought the sd card from these guys thay r realy good you can have buy the sd card for your navigation for all model i have bought nscp-w61 for my prius and its work perfect i found this add on internet if any one having problem with password or with softwere conteact them thanks
Software and password solution for :
NSCP-W61NSCP-W62NSDD-W60NSDD-W61NSDD-W62NSZT-W60GNSZT-W61GNSZT-W62G
if you have facing problem contact us.
