Its Working Firing And Starting...Its Good....And Sanuu Kii If You Complain....
If Its Not.....its Bad...! Which Means Wire Should Be Literally Chopped Off Or Cutted With Knife So It Won't Work Else It Will Work Somehow....
Readings Are Insanely HIGH For The Length Of Wires
In General 4000-5000 Ohms Resistance Is Expected In One Ft(12") ...
If Its Bad Or Not As Good As OEM... Make It 8000 OHms Per 12"
None Of Your Wire Is More Than 24"(2 Ft) Sp 4.5k OHms Is Like U Put Some Resistance In It....!!
As Per Your Readings And Length You Are Having Around 30,000 OHMs Resistance Per Ft(12")
Kadooo Spark Aaega ....Even Busted Factory Wires Have less Resistance Than This... I Would Suggest To Try Get Them Replace And Check For Other Set....If He Don't........Check The Crimped Ends And Make Sure They Are Good...If These Are CHEAP......Surely The Conductor Used Is Also Cheap......So Al-Fatiha On These And Hunt For New....!
In Karachi We Have ULTIMA Wires Available...Which Are quiet OK...Resistance Is Good......But They Don't Like Hot Environment And Playing With Them On Monthly Basis To Clean Plug......Because They Have Loose Boots And It Get Dislocated..Else They Are Good....
