Today Toyota released the entirely newly developed 2016 Passo and is on sale in Japan as of today. The new Passo is available in two grades; X and Moda. Moda is the upscale version of X with upgraded exterior which gives it a sporty look. The newly designed car gives an increased leg room of 3″ in the rear which is impressive. The front gets a newly designed ring-shaped Bi-Beam LED headlamps while redesigned tail lights gives Passo new face. The interior is also new with new dashboard, cluster and media center. All versions of the Passo will be powered by a new 1KR-FE ; 1000CC engine. Both front wheel drive and All wheel drive will be available. A CVT transmission will be standard across the model line up. Toyota said that the new model is based on lighter and stronger chassis and body and have the highest fuel economy in the segment in entire Japan. The FWD model will provide a 28km/L while a AWD model will have a fuel economy of 24.4Km/L. The new Passo is safer than ever with side outer panels made high-tensile strength steel. The suspension is also equipped with stabilizers on front and rear to reduce the roll over risk and increase stability. Passo is also equipped with a number of active safety features known as Smart Assist II; comprised of collision warning system for pedestrians and vehicles, collision avoidance brake assist function, line deviation warning. The hatchback will also be equipped with driver + passenger as well as side curtain air bags.The new Passo will be available in wide variety of colors; 12 in total and will cost 1,150,200 yen [ PKR 1109427/- before taxes and duties] for the FWD model and 1,431,000 yen [ PKR 1380273/- before taxes and duties] for the Moda
Nice, but i guess current shape looks more Cool
Same engine ????IKR-FE
Wow great...finally toyota added some goodies in 1000cc line up.Interior of passo is great ... current shape sucks big time in terms of interior.The moda series is direct copy of mini Cooper[emoji14]
Sent from my SM-N920C using Tapatalk
Amazing
Sent from my XT1080 using PW Forums mobile app
Yes.............
looking cool.i've observed every generation of passo have nice shape but it doesnt have angry look like vitz have. same is the case with this upcoming gen ,well still nice than new model ugliest alto
Passo now comes with 1000cc engine only. Previous gen had 1300cc as well.
And that 1.3 used to be 1NR-FE having 74 kW (99 bhp) at 6000 rpm with 132 N?m (97.4 lb?ft) at 3800 rpm
much powerful than the 1.3 2NZ-FE which is 63 kW (84 hp) at 6000 rpm with 121 Nm (89 lb?ft) of torque at 4400 rpm
Steering is awesome loved it.
Sent from my INFINIX-X551 using Tapatalk
Interior is good....back looks awesome....front looks a bit odd.
Now interior looks much better! Especially the steering wheel.
But it's bad side was that it was 1300cc+ and that is why it can never be imported to Pakistan
1300cc+ cars can never be imported to Pakistan ??
