Daihatsu Hijet 2012
Transmission is Automatic
Initially on start the A/C works fine on all gears but after a little drive, it only works as long as feet is on accelerator. Constant speed or accelerating. But every time the car stops at signals, the A/C trips, it doesn’t turn back on on N and P gear either. But once you start driving, it comes back ON. Also A/C performance decreases when accelerating or constant speed.
Any suggestions will be highly appreciated. Mechanic says all is good. A/C guy says you need to service the A/C.
