I want to know my gli 2010 has completed 10,000km and what toyota motors do service at 10000.What should be checked at this.If u have any know how do share me ur experience
I also want to install altis odometer i called toyota they told me the price is 70000.I was shoked .Can any one also tel me that can we purchase in open market the odo meter of altis 2012
Brand new costs around 25k, Iguess there is this shop "Shahid Autos" in lahore they have them
Do not install altis odo
further more on 10k they should change oil, oil filter, air filter and tire rotation
Will it show the same door open indication like Altis? I mean the door which is open will be indicated?
In addition to what qwertpoiu said, they will check all the nut bolts of car. It is not confirmed that they will do brake service or not.
Sent from my Nokia 3310 using Tapatalk
Double.
Bro can you tell the reason for being so against altis odo in gli?Any personal experience involved you would like to share?
why? :s
Here u go bro
I have been provided with this sticker from my dealership . Hope it will help u.
@qwerty, Why?
@raza, Its a clip to clip fix, Tell you evrything, But iguess the feature of turning on meter lights on door open doesnt works, Im not sure im saying what i read on Pakwheels, Im not sure the name of the pakwheelers, He has it in his black gli/Xli he also has black headlamps,
Why you want to istlall altis ODO meter
What should we do after 80k? Contact local ustad ji, lolz.
@chinyoti brother, thanks a lot, i have also seen somewhere on pw, will search him.
they will change engine oil,oil filter, wheel balancing, alignment ,brake service and will clean cabin and air filter with air
Raza yar if you are able to find the person who got altis odo in corolla plz let me know as well.
thanks bro for replying me and guiding me .any way my 2nd problem i want to install altis odo meter any one who has installed and any one knows the price in market do share
I noticed what u did there...3310
It should be plug n play. But i am confused of two things; door wise indication and cruisetronic display in cluster.
:oSent from my Nokia 3310 using Tapatalk
Oil and oil filter change, air filter element will be changed or cleaned (depends on its condition) Cabin AC filter will be cleaned, wheel balancing and tyre rotation, throttle body service (If needed) Front brake service.
bro tell me when this cabin ac filter needs to be changed or it will be just cleaned every times it get clogged like the filters in home ACs
It depends, if you keep the fresh air button off (means inner circulation is on) then it will need cleaning on weekly basis. Otherwise on monthly basis. I clean it myself on monthly basis.
