Asalam o Alaikum everyone!
It’s my first post on the forum. I need some help
I bought honda city idsi a year ago and had to replace it’s engine recently. I swapped L12A2 with L15A, it worked fine for a while and then got a check light for O2 sensor but still got light back on after month of changing o2 sensor. Now the final diagnosis is that my ecu is faulty not the sensor. Original ecu that is currently installed is K4 (i will attach photo) but I am unable to find used ecu for pakistan assembled MT idsi from market. Can find japanese ecu for A/T though.
So the question is which other ecu can I use with L15A and M/T for my car? And if I somehow use ecu from a japanese car with A/T, can I also get my egr connected to it because currently its not connected because of original ecu for manual transmission. My electrician says he can make A/T check light go away it I use Ecu from A/T.
Thanks in advance for help and guidance
