1984 - 1990
- Production period in Japan.
The period of introduction for this generation model may vary by region.
BJ70
BJ70V
BJ70V LX
table cellpadding=0" cellspacing=0" width=719"
tbody
DIMENSIONS
Overall, length
3,975mm
Overall, width
1,690mm
Overall, height
1,870mm
Wheelbase
2,310mm
Tread, front
1,425mm
Tread, rear
1,420mm
Ground clearance
185mm
Seating capacity
2 (5) Passengers
Turning radius
5.3m
WEIGHT
Net vehicle weight-
1,790kg
Gross vehicle weight
2,300kg
Payload
400(0)kg
ENGINE
Type
Model 3B, diesel engine, OHV
Cylinders
in-line 4
Bore x stroke
102.0 x 105.0mm
Displacement
3.431cc
Compression ratio
20.0
Maximum net power
98PS/3,500 r.p.m.
Maximum net torque
23.0kg-m/2,200 r.p.m.
Gasolin tank capacity
90 liters
TRANSMISSION
5 M/T
Gear ratio
: 1st 4.843
: 2nd 2.618
: 3rd 1.516
: 4th 1.000
: 5th 0.845
: reverse 4.843
TRANSFER
Gear ratio
: high 1.000
: low 1.960
Axle ratio
4.111
SUSPENSION
Front
semi-elliptic leaf spring
Rear
STEERING GEAR
ball-and-nut
BRAK
Front
disc
Rear
drum
TIRE
215SR15
/tbody
/table
BJ73V LX
tbody
DIMENSIONS
Overall, length
4.265mm
Overall, width
1,690mm
Overall, height
1,915mm
Wheelbase
2,600mm
Tread, front
1,425mm
Tread, rear
1,420mm
Ground clearance
210mm
Seating capacity
2 (5) Passengers
Turning radius
5.3m
WEIGHT
Net vehicle weight
1,830kg
2,340kg
Payload
400(250)kg
ENGINE
Type
Cylinders
in-line 4
Bore x stroke
102.0 x 105.0mm
Displacement
3.431cc
Compression ratio
20.0
Maximum net power
98PS/3,500 r.p.m.
Maximum net torque
90 liters
TRANSMISSION
5 M/T
Gear ratio
: 1st 4.843
: 2nd 2.618
: 3rd 1.516
: 4th 1.000
: 5th 0.845
: reverse 4.843
TRANSFER
Gear ratio
: high 1.000
: low 1.963
Axle ratio
4.111
SUSPENSION
Front
Rear
STEERING GEAR
ball-and-nut
BRAKE
Front
disc
Rear
drum
TIRE
215SR15
/tbody
/table
BJ71V LX
tbody
DIMENSIONS
Overall, length
3,975mm
Overall, width
1,690mm
Overall, height
1,870mm
Wheelbase
2,310mm
Tread, front
1,425mm
Tread, rear
1,420mm
Ground clearance
185mm
Seating capacity
2 (5) Passengers
Turning radius
5.3m
WEIGHT
Net vehicle weight
1,820kg
2,330kg
Payload
400(0)kg
ENGINE
Type
Model 13B-T, diesel engine, OHV,turbo
Cylinders
in-line 4
Bore x stroke
102.0 x 105.0mm
Displacement
3,431cc
Compression ratio
17.6
Maximum net power
120PS/3,400 r.p.m.
Maximum net torque
29.0kg-m/2,000 r.p.m.
Fuel Tank Capacity
90 liters
TRANSMISSION
5 M/T
Gear ratio
: 1st 4.843
: 2nd 2.618
: 3rd 1.516
: 4th 1.000
: 5th 0.845
: reverse 4.843
TRANSFER
Gear ratio
: high 1.000
: low 1.963
Axle ratio
4.111
SUSPENSION
Front
Rear
STEERING GEAR
ball-and-nut
BRAKE
Front
disc
Rear
drum
TIRE
215SR15
/tbody
/table
BJ74V LX
tbody
DIMENSIONS
Overall, length
4,265mm
Overall, width
1,690mm
Overall, height
1,915mm
Wheelbase
2,600mm
Tread, front
1,425mm
Tread, rear
1,420mm
Ground clearance
185mm
Seating capacity
2 (5) Passengers
Turning radius
5.8m
WEIGHT
Net vehicle weight
1,870kg
2,380kg
Payload
400(250)kg
ENGINE
Type
Cylinders
in-line 4
Bore and stroke
102.0 x 105.0mm
Displacement
3,431cc
Compression ratio
17.6
Maximum net power
120PS/3,400 r.p.m.
Maximum net torque
90 liters
TRANSMISSION
5 M/T
Gear ratio
: 1st 4.313
: 2nd 2.330
: 3rd 1.436
: 4th 1.000
: 5th 0.838
: reverse 4.220
TRANSFER CASE
Gear ratio
: high 1.000
: low 2.295
Axle ratio
4.875
SUSPENSION
Front
Rear
STEERING GEAR
ball-and-nut
BRAKE
Front
ventilated disc
Rear
drum
TIRE
215SR15
/tbody
/table
1990 -
HZJ77HV
HZJ73HV
HZJ77HV ZX
tbody
DIMENSIONS
Overall, length
4,805mm
Overall, width
1,790mm
Overall, height
1,935mm
Wheelbase
2,730mm
Tread, front
1,455mm
Tread, rear
1,440mm
Ground clearance
215mm
Seating capacity
2 (5) Passengers
Turning radius
6.1m
WEIGHT
Net vehicle weight
2,130kg
2,640kg
Payload
400(250)kg
ENGINE
Type
Model 1HZ, diesel engine, OHC
Cylinders
in-line 6
Bore x stroke
94.0 x 100.0mm
Displacement
4,163cc
Compression ratio
22.7
Maximum net power
135PS/4,000 r.p.m.
Maximum net torque
28.5kg-m/2,200 r.p.m.
Fuel Tank Capacity
90 liters
TRANSMISSION
4 A/T
Gear ratio
: 1st 2.950
: 2nd 1.530
: 3rd 1.000
: 4th 0.717
: reverse 2.678
TRANSFER
Gear ratio
: high 1.000
: low 2.295
Axle ratio
4.111
SUSPENSION
Front
Rear
STEERING GEAR
ball-and-nut
BRAKE
Front
ventilated disc
Rear
ventilated disc
TIRE
31 x 10.5R15
/tbody
/table
HZJ73HV ZX
tbody
DIMENSIONS
Overall, length
4,455mm
Overall, width
1,790mm
Overall, height
1,950mm
Wheelbase
2,600mm
Tread, front
1,455mm
Tread, rear
1,440mm
Ground clearance
215mm
Seating capacity
2 (5) Passengers
Turning radius
5.8m
WEIGHT
Net vehicle weight
2,020kg
2,530kg
Payload
400(250)kg
ENGINE
Type
Cylinders
in-line 6
Bore and stroke
94.0 x 100.0mm
Displacement
4,163cc
Compression ratio
22.7
Maximum net power
135PS/4,000 r.p.m.
Maximum net torque
Fuel Tank Capacity
90 liters
TRANSMISSION
5 M/T
Gear ratio
: 1st 4.843
: 2nd 2.618
: 3rd 1.516
: 4th 1.000
: 5th 0.845
: reverse 4.843
TRANSFER
Gear ratio
: high 1.000
: low 1.963
Axle ratio
4.111
SUSPENSION
Front
Rear
STEERING GEAR
ball-and-nut
BRAKE
Front
ventilated disc
Rear
ventilated disc
TIRE
31 x 10.5R15
/tbody
/table
PZJ77V LX
tbody
DIMENSIONS
Overall, length
4,685mm
Overall, width
1,690mm
Overall, height
1,900mm
Wheelbase
2,730mm
Tread, front
1,415mm
Tread, rear
1,410mm
Ground clearance
200mm
Seating capacity
2 (5) Passengers
Turning radius
6.1m
WEIGHT
Net vehicle weight
1,590kg
2,460kg
Payload
400(250)kg
ENGINE
Type
Model 1PZ, diesel engine, OHC
Cylinders
in-line 5
Bore and stroke
94.0 x 100.0mm
Displacement
3,469cc
Compression ratio
22.7
Maximum net power
115PS/4,000 r.p.m.
Maximum net torque
23.5kg-m/2,600 r.p.m.
Fuel Tank Capacity
90 liters
TRANSMISSION
5 M/T
Gear ratio
: 1st 4.313
: 2nd 2.330
: 3rd 1.436
: 4th 1.000
: 5th 0.838
: reverse 4.220
TRANSFER
Gear ratio
: high 1.000
: low 1.963
Axle ratio
4.111
SUSPENSION
Front
Rear
STEERING GEAR
ball-and-nut
BRAKE
Front
ventilated disc
Rear
drum
TIRE
215/80R16
/tbody
/table
PZJ70V STD
tbody
DIMENSIONS
Overall, length
4,045mm
Overall, width
1,690mm
Overall, height
1,885mm
Wheelbase
2,310mm
Tread, front
1,415mm
Tread, rear
1,410mm
Ground clearance
200mm
Seating capacity
2 (5) Passengers
Turning radius
5.3m
WEIGHT
Net vehicle weight
1,790kg
2,300kg
Payload
400(0)kg
ENGINE
Type
Cylinders
in-line 5
Bore and stroke
94.0 x 100.0mm
Displacement
3,469cc
Compression ratio
22.7
Maximum net power
115PS/4,000 r.p.m.
Maximum net torque
Fuel Tank Capacity
90 liters
TRANSMISSION
5 M/T
Gear ratio
: 1st 4.313
: 2nd 2.330
: 3rd 1.436
: 4th 1.000
: 5th 0.838
: reverse 4.220
TRANSFER
Gear ratio
: high 1.000
: low 1.963
Axle ratio
4.111
SUSPENSION
Front
Rear
STEERING GEAR
ball-and-nut
BRAKE
Front
ventilated disc
Rear
drum
TIRE
215/80R16
/tbody
/table
1985 - 1996
LJ71G
KZJ71G
KZJ78W
LJ71G WAGON
tbody
DIMENSIONS
Overall, length
3,975mm
Overall, width
1,690mm
Overall, height
1,865mm
Wheelbase
2,310mm
Tread, front
1,425mm
Tread, rear
1,420mm
Ground clearance
205mm
Seating capacity
5 Passengers
Turning radius
5.3m
WEIGHT
Net vehicle weight
1,680kg
1,955kg
ENGINE
Type
Model 2L-T, diesel engine, turbo
Cylinders
in-line 4
Bore and stroke
92.0 x 92.0mm
Displacement
2,446cc
Compression ratio
20.0
Maximum net power
85PS/4,000 r.p.m.
Maximum net torque
19.2kg-m2,400 r.p.m.
Fuel Tank Capacity
90 liters
TRANSMISSION
5 M/T
Gear ratio
: 1st 4.313
: 2nd 2.330
: 3rd 1.436
: 4th 1.000
: 5th 0.838
: reverse 4.220
TRANSFER
Gear ratio
: high 1.000
: low 2.295
Axle ratio
4.875
SUSPENSION
Front
trailing type, rigid axle with coil springs
Rear
STEERING GEAR
ball-and-nut
BRAKE
Front
disc
Rear
drum
TIRE
215/SR15
/tbody
/table
LJ78G PRADO EX5
tbody
DIMENSIONS
Overall, length
4,585mm
Overall, width
1,690mm
Overall, height
1,905mm
Wheelbase
2,730mm
Tread, front
1,415mm
Tread, rear
1,415mm
Ground clearance
205mm
Seating capacity
8 Passengers
Turning radius
6.1m
WEIGHT
Net vehicle weight
1,920kg
2,360kg
ENGINE
Type
Model 2L-TE, diesel engine, turbo
Cylinders
in-line 4
Bore and stroke
92.0 x 92.0mm
Displacement
2,446cc
Compression ratio
21.0
Maximum net power
97PS/3,800 r.p.m.
Maximum net torque
24.5kg-m/2,400 r.p.m.
Fuel Tank Capacity
90 liters
TRANSMISSION
4 A/T
Gear ratio
: 1st 2.804
: 2nd 1.531
: 3rd 1.000
: 4th 0.753
: reverse 2.393
TRANSFER
Gear ratio
: high 1.000
: low 2.295
Axle ratio
4.875
SUSPENSION
Front
Rear
STEERING GEAR
ball-and-nut
BRAKE
Front
ventilated disc
Rear
ventilated disc
TIRE
215/80R16
/tbody
/table
KZJ71W PRADO SX WIDE
tbody
DIMENSIONS
Overall, length
3,975mm
Overall, width
1,790mm
Overall, height
1,880mm
Wheelbase
2,310mm
Tread, front
1,455mm
Tread, rear
1,455mm
Ground clearance
200mm
Seating capacity
5 Passengers
Turning radius
5.3m
WEIGHT
Net vehicle weight
1,780kg
2,055kg
ENGINE
Type
Model 1KZ-TE, diesel engine, turbo
Cylinders
in-line 4
Bore and stroke
96.0 x 103.0mm
Displacement
2,982cc
Compression ratio
21.2
Maximum net power
130PS/3,600 r.p.m.
Maximum net torque
29.5kg-m/2,000 r.p.m.
Fuel Tank Capacity
90 liters
TRANSMISSION
4 A/T
Gear ratio
: 1st 2.804
: 2nd 1.531
: 3rd 1.000
: 4th 0.753
: reverse 2.393
TRANSFER
Gear ratio
: high 1.000
: low 2.295
Axle ratio
4.300
SUSPENSION
Front
Rear
STEERING GEAR
ball-and-nut
BRAKE
Front
ventilated disc
Rear
ventilated disc
TIRE
265/70R15
/tbody
/table
KZJ78W PRADO SX WIDE
tbody
DIMENSIONS
Overall, length
4,615mm
Overall, width
1,790mm
Overall, height
1,885mm
Wheelbase
2,730mm
Tread, front
1,455mm
Tread, rear
1,455mm
Ground clearance
200mm
Seating capacity
8 Passengers
Turning radius
6.1m
WEIGHT
Net vehicle weight
1,930kg
2,370kg
ENGINE
Type
Cylinders
in-line 4
Bore and stroke
96.0 x 103.0mm
Displacement
2,982cc
Compression ratio
21.2
Maximum net power
130PS/3,600 r.p.m.
Maximum net torque
Fuel Tank Capacity
90 liters
TRANSMISSION
4 A/T
Gear ratio
: 1st 2.804
: 2nd 1.531
: 3rd 1.000
: 4th 0.753
: reverse 2.393
TRANSFER
Gear ratio
: high 1.000
: low 2.295
Axle ratio
4.300
SUSPENSION
Front
Rear
STEERING GEAR
ball-and-nut
BRAKE
Front
ventilated disc
Rear
ventilated disc
TIRE
265/70R15
/tbody
/table
