I recently bought a used 2000 model cuore.it was checked by my friend & car electrician who told us about this car.i don't know about car history of repairs but body is good in shape.my friend checked body for rust& said OK while electrician recommended to buy saying if you spend 20-25K on car it will be fit.i bought car in 3lac 20 thousands.i took car to Toyota workshop for checkup.They told suspension needs work,front wheel bearing,left lower arm bush,tie rod work,steering boot,caliper kit,rear wheel bearing etc.Tomorrow they will tell me cost of new parts.Labour charges will be 4000 & steering reula repair will be 2000.
Now about engine they told it is weak,needs overhaul,timing seal & some other seals are leaking,water is mixing with oil,crank sound on high acceleration.For engine work Toyota mechanic says if I purchase Toyota parts it will cost around 1 lac & if I fix deal with mechanic it will cost around 65K he will use kabli parts.
Tyres also need to be replaced.
I am learning driving these days.Please suggest how should I proceed.Keep learning to drive without any work on car ?Do suspension,wheels work first & engine in the end?any other suggestion.![]()
