Hi,
I own a Suzuki Khyber & its left CV Joint was making a knocking sound when making turns so i fixed the problem my self which u too can do.
Step 1: Remove the wheel, turn it to full right if u are working on the left one.
Remove the rubber boot locks using a flat screw driver & nose pliers ( there are 2 of those strip locks).
Step 2: Push the boot towards the engine so that the CV joint is clearly visible:
Step 3: U will observe that the existing grease has turned Black in colour & has lost its viscosity that is why the knocking sound is heard as in the pic:
Step 4: Remove all that dirty old grease By applying WD 40 & a mixture of Petrol + Diesel in a bottle having a pin hole inside the top lid
Step 5:
Apply now new grease, i used a Hi-speed water proof grease courtesy of AMS OIL, USA.
Step 6: Keep turning the hub so that the grease is applied fully infact add some inside the boot after removing the old one from it.
Step 7: place back the boot & the boot ties & have a test drive on bends to hear if the knocking has become silent or not.
