@talhawaleed brother
First of all thankyou so much for such a detailed and informative thread and a bundle of thanx for even maintaining it and helping poeple with your exeperience
please guide me with your valuable advice for the following queries below...
"By rule of thumb the maximum allowable charging rate of Lead Acid batteries are its Amp Hour rating divided by 10. For 145 AH battery; the correct charging rate is 145 AH/10 is 14.5 Volts"
14.5 volts as in?
1:: ups should trip/stop charging once battery reaches at 14.5 volts.
2:: the potential difference (the DC Charging Current) between the UPS terminals should be at 14.5 volts??
if its the first point then in how much time should the ups charge the battery upto 14.5 volts ??
if its the second point then what should be the Volts of battery at which the ups should stop charging the battery ??
secondly, while reading the latter part of the post.. i came across this ....
"Adjust the charging rate of each battery such that (AMP HOUR rating divided by 10). E.g For 200 AMP-HR batteries, I can keep it somewhere closer to 15 Amperes but will never exceed 20 amperes."
above you said,
145 AH/10= 14.5 volts
later u said 200 AH/10 = 20 amp ? shouldn't be the volts ?? as in 20 Volts ??
and after answering and guiding me with all these quieries...
kindly come to the points.. below ...
i have an 175 AH Osaka battery and thinking to flush it... (since its in service for almost 1 year now and never changed the electrolyte just topped it up with water 2 or 3 times hardly ermm tap water)
i'll follow the instruction given by you ofcourse.. (thanx for that detailed explanation really your the man
now the thing i am planning is get an electrolyte from PYRO chemicals (near model town, lahore) but i have a question how much to fill the cells actually ?? full to the roof of the battery?? or i should fill it to the level so that only cells gets dipped in the elctrolyte and than top it up with distilled water ??
and errmm can you share the rates of PYRO battery electrolyte per liter ? and battery watter (distilled water) per liter ??
what should be the amp of ups to charge a 175Ah battery?? In given situations...
1:: if its new and first time electrolyte is added..
2:: if it is 2 to 3 months old battery... ??
